Displays RIPng-specific configuration and statistics for the specified interface.
| detail | Specifies detailed display. |
| vlan-name | Specifies an IPv6 configured VLAN. |
| tunnel-name | Specifies an IPv6 tunnel. |
Show summary output for all interfaces.
Displays the RIPng interface configuration and runtime information. If no interface is specified, only the summary data for all the configured interfaces is displayed. If an interface is specified, only the data for that interface is displayed in detail. If the keyword detail is specified, detailed data for all interfaces is displayed.
The following command displays the RIPng configuration summary for all interfaces:
show ripng interface
The following is sample output from this command:
VLAN IP Address Flags Sent Rcvd Triggered Cost
Packets Packets Updates
v1 22cc::3 /64 rif-pst 106349 106349 3 15
v2 22bb::1 /64 rif-pst 106349 106095 3 1
v3 2abc::1 /120 rif-pst 106351 0 4 1
v4 3ffe::1 /64 rif-pst 106349 139124 3 1
Flags: (f) Interface Forwarding Enabled, (i) Interface RIPng Enabled
(n) Multinetted Interface, (r) Router RIPng Enabled
(p) Poison Reverse Enabled, (s) Split Horizon Enabled
(t) Trigerred Update Enabled.
The following command displays RIPng-specific statistics for the VLAN v1:
show ripng interface v1
VLAN : v1 Interface : 22cc::3/64 Router RIPng : Enabled Cost : 15 Input Policy : None Output Policy : None Trusted GW Policy : gw6 Poison Reverse : Enabled Split Horizon : Enabled Triggered Updates : Enabled Rcved Packets : 106358 Sent Packets : 106358 Sent Trig. Updates : 3 Rcved Bad Packets : 0 Rcved Bad Routes : 0 Neighbor Addresses : fe80::201:30ff:fe94:f400 Interface Addresses : 22cc::3/64, fe80::280:c8ff:feb9:2855/64
This command is available on platforms with an Edge, Advanced Edge, or Core license. For licensing information, see the Switch Engine v33.1.1 Licensing Guide document.
